04-05-2018 07:19
04-05-2018 07:19
Will the Versa will track laps when you are walking in a aqua track/resistance pool? I had a flex 2 that did track laps but only on an intermittent basis, even though I was consistent in moving my arms through the water as I walked....
04-05-2018 17:04 - edited 04-05-2018 17:05
@esw1951 Welcome to the Fitbit Community!
Versa is optimized to track laps only when completing a swim exercise. If you will be swimming, then you can input the pool length to track accurate laps. The optical sensor does not record heart rate data when the device is in swim mode because refractions from the water can impact the heart rate reading. If you will be solely walking in a pool, you can use the "walk" exercise shortcut. In walk mode, you cannot track laps. Also, keep in mind heart rate accuracy will be affected because of refractions from the water.
If you still have any questions, please let me know! Hope this was helpful.
04-05-2018 08:58 - edited 04-05-2018 08:59
If you leave it to Smart Track I doubt it will be any different, but if you use the exercise mode it should work. You would just have to work out whether to use walk or workout (and change the name afterwards), though I dont think it would track laps
Helen | Western Australia
04-05-2018 10:14
04-05-2018 10:14
Thanks for the reply. Let me clarify.... I do currently have the charge 2 and it works fine (except that I can't use it in the pool). I don't want to spend $200 for the Versa only to find that while it should work, it doesn't work well and consistently in the scenario I described. So, I'm hoping to hear from someone who has had experience using the Versa to track laps, time, calories burned and heart rate during pool water walking.
04-06-2018 06:08
04-06-2018 06:08
thank you.
06-26-2018 18:51
06-26-2018 18:51
On the response it says to track jogging in the water as walking but the water offers much more resistance than walking on a track or inside. Also, how does it support water aerobics?
If a person is exercising on a recumbent bike where their arms are stationary, is it able to register the exercise? With the tracker I currently own I have to put it on my shoe to track this type of exercise, or using a treadmill while holding on.
Thank you
06-26-2018 19:48
06-26-2018 19:48
Thank you
