03-20-2018
08:23
15:00
AlessFitbit
03-20-2018
08:23
15:00
AlessFitbit
How to transfer data stored on Galaxy S8 when changing from Charge 2 to Versa?
Moderator edit: title for clarity
Best Answer03-20-2018 08:30 - edited 03-20-2018 08:32
You don't need to. The data isn't actually stored on the device. All the data is synced to Fitbit's servers.
All you need to do is go to the account section in the fitbit app, then set up new device and the transition is seamless.
03-20-2018 08:31
03-20-2018 08:31
All your data is held on the fitbit servers rather than the fitbit so there is nothing you need to do.
When you get your versa just add it as a new device in the app. You can choose to keep the Charge 2 connected to your account or remove it. Either way, all your data, settings, badges etc will be retained.
Just remember to give the Charge 2 one last sync before you remove it.
03-20-2018 08:36
03-20-2018 08:36
Thank you.
Best Answer03-20-2018 08:37
03-20-2018 08:37
@SteveHwrote:All your data is held on the fitbit servers rather than the fitbit so there is nothing you need to do.
Thank you.
03-20-2018 08:38
03-20-2018 08:38
@N8teGeewrote:You don't need to. The data isn't actually stored on the device. All the data is synced to Fitbit's servers.
Thank you.
09-23-2018 02:36
09-23-2018 02:36
That didn’t happen to me. When I changed devices (from Iphone 7+ to XS), the fitbit did not restore any of the data I had on my previous phone. How do I get it back?
