11-10-2018 23:03
11-10-2018 23:03
Hi,
When I turn off the Heart Rate Monitor from the Settings, the green light is still active and flashing when I place the watch on my wrist? I would like it to stop when it is turned off. Is there a way to turn it off permanently?
Best Answer11-11-2018 01:11
11-11-2018 01:11
I'm afraid not. For some reason fitbit designed the heart rate lights to remain on:
"Note that the green LED on the back of Versa continues to flash even if you turn off heart rate tracking."
Taken from page 41 of the manual at https://staticcs.fitbit.com/content/assets/help/manuals/manual_versa_en_US.pdf
11-11-2018 01:45
11-11-2018 01:45
Thanks @SteveH.
Is there a reason why it's doing that, even though we are not using that functionality? To me that feels like a waste of battery life, when you need to conserve it as much as possible. I think there are some users (me included) that do not feel comfortable having a green light beamed directly onto the body as well.
How come Fitbit is not providing an update to fix this issue?
Best Answer11-11-2018 01:52
11-11-2018 01:52
As it's working in the way they designed it to, they probably do not view this as an issue to be fixed.
It does seem a strange design choice as other fitbit models do stop the lights when heart rate monitoring is turned off.
You could create a feature suggestion to change the way this works in the dedicated area of the community at https://community.fitbit.com/t5/Feature-Suggestions/idb-p/features
However, feature suggestions, even if accepted, rarely happen quickly so if the heart rate lights are an issue for you then perhaps fitbit is not for you.
