08-25-2022
10:33
17:20
08-25-2022
10:33
17:20
Had an Ionic that worked well. It was recalled.
Versa 3 (#1) replacement worked well for a couple of weeks. Received a replacement.
Versa 3 (#2) .Would not pair. Stuck at 0%. Talked to Fibit rep for an hour going over procedures. Could not fix it so got another replacement.
Versa 3 (#3) Same result as #2. Possible problems - #1 Cellphone reports Versa 3 battery empty but the Versa 3 shows 100%. #2 - Troubleshooting hint said check Firewalls. Don't know how to do that.
Somebody please help.
I miss the ability to download my music to Fitbit. It looks like no smartwatches have that capability.
08-25-2022
20:55
13:20
08-25-2022
20:55
13:20
Hi @Intruder145 - Fitbit are dropping music support. Most other brands have it though.
The disparity of battery between the app and the watch is because the watch is not syncing, the app is showing an historic value, check when it last synced (click profile photo, device photo and at the top).
On your phone remove any Fitbit Bluetooth entries.
In the Fitbit App, click profile photo and "+ Set up a Device" and replace.
Best Answer08-26-2022 09:30
08-26-2022 09:30
08-29-2022 07:11
08-29-2022 07:11
It is fixed. I just kept doing the same process over and over., without following any of the suggestions. When I reached sync, instead of stalling at 0% it went to 100%. Appreciate the replies.
