Unable to update replacement Versa.
on my second versa after first one being faulty. on 3rd day of trying to set it up, gets to an update stage then wont load. tried on phone a laptop several times rapidly loosing patience with it. any help would be appreciated. ta
1 REPLY 1
Hello @sionge, have a warm welcome to the Fitbit Community, it's great to see new faces around! Smiley Happy
Thanks for bringing this to my attention. I appreciate you have already tried to update your Versa. Before you begin the firmware update, make sure your watch is plugged into the charger and in range of your Wi-Fi network during the update. For best results, use your home or work Wi-Fi network. If you've never connected your watch to WiFi, see How do I connect my Fitbit watch to Wi-Fi?. If your Versa is having trouble updating with WiFi, please try the following:
  1. Make sure your watch is connected to the Wi-Fi network you want to use.
  2. Move your watch closer to your router.
  3. Make sure your router is connected to the internet.
  4. Restart your watch by holding the back (left) and bottom buttons until you see the Fitbit logo.
  5. Try again to update your watch.
If the update fails, restart your mobile device and try to update again. If you your Versa can't update over WiFi follow the on-screen instructions in the Fitbit app to update your watch over Bluetooth instead. Note that firmware updates over Bluetooth may take significantly longer to complete. If the Versa is having trouble updating through Bluetooth try the following:
  1. Try turning Bluetooth on and off on your phone.
  2. Restart your watch by holding the back (left) and bottom buttons until you see the Fitbit logo.
  3. Try again to update your watch.
  4. Restart your mobile device and try to update again.
I hope this can be helpful, give it a try and keep me posted in case you need anything else.
