01-27-2020 20:45 - last edited on 01-29-2020 10:14 by LiliyaFitbit
How do you unlock fit bit versa when you got rid of your old phone? Have looked all over the app cant seem to find anything that is working.
01-29-2020 11:22
01-29-2020 11:22
Welcome to the Fitbit Community, @Tiareid. I am sorry for the delayed response.
I appreciate your participation in the Forums and sharing your concern about unlocking your Fitbit Versa. Since you're unable to unlock your device with your phone, I recommend doing a factory reset. Please note that you will need to reinstall any apps on your device after the reset, and if you couldn’t sync the device, then any data on the Fitbit device will be lost. In order to do the factory reset, please do the following:
Let me know how it goes, I'll be around.
