07-12-2018 04:16
07-12-2018 04:16
I was wondering if there is an app or another way to see battery usage statistics of the Versa.
I am particularly thinking about getting the time since last charge, screen time on and other such information.
Any idea if this exists or not ?
07-12-2018 07:38
07-12-2018 07:38
@Kulfsson wrote:.
I don't believe so.
07-12-2018 08:00
07-12-2018 08:00
What OS (ie. iOS, Android, etc), and OS version do you use?
07-12-2018 08:05
07-12-2018 08:05
Android 5.0.
07-12-2018 08:07
07-12-2018 08:09
07-12-2018 08:09
@tofuuu630 wrote:
@SunsetRunner wrote:Android 5.0.
I was asking @Kulfsson
Your post didn't indicate that!
07-12-2018 09:04
07-12-2018 09:04
I am running a Samsung S8 with Android 8.
07-12-2018 09:44
07-12-2018 09:44
If you go into Settings -> Battery, you will be able to see a breakdown of the apps using up your battery and how much data it is being used. Depending on TouchWiz skin on Android, you also might be able to see how many minutes it is running in the fore/background.
07-12-2018 11:31
07-12-2018 11:31
Yes, that is exactly what I want... but.. for the Versa watch. i.e. being able to open an app that will show me these stats with regards to the watch. Let's say, how many hours since last charge, how many hours the screen has been on, how many hours a specific app has been running etc.
