08-16-2018 06:37
08-16-2018 06:37
I'm interested in the Versa but would like to know how easy it is to use with two phones.
I have an old Samsung S5 that I take out running, and an S8 which is my phone all the rest of the time. It seems that the Versa does not have built-in GPS, so will I need to unpair from one phone and repair to the other every time I go out for a run, and switch them around again when I finish? Or will it work with both phones without the need for any fiddling about?
Many thanks.
Best Answer08-16-2018 09:02
08-16-2018 09:02
Hi @MrFrisk
No need to do anything other than add the Fitbit app to the old phone. I have an old phone I use and can sync with and my current phone, plus my tablet and my computer - I'm connected!
Since the device pairs to the email address, it makes it much easier for us to change devices.
Give it a try and let us know how things work out for you.
08-16-2018 11:18
08-16-2018 12:25
08-16-2018 12:25
@MrFrisk I just want to add that if you get notifications on your newer phone, you might need to disable the notifications to connect with the older phone -- I am an iOS user, but I'm sure this is also true for Android phones. When you receive notifications, there is a tight Bluetooth bond between your tracker and that phone.
It took me a little while to figure out why I couldn't sync with my tablet.
Laurie | Maryland
08-16-2018 12:28
08-16-2018 12:28
The only drawback is that the Versa, like most Bluetooth devices will only communicate with one device at a time. Since both phones will not be with you during a run, this ilwill not be a problem.
However once home, you may need to turn at least the bluetooth off on the old phone.
