12-28-2018 16:20
12-28-2018 16:20
HOW DO I GET RID OF THE WEATHER NOTIFICATION
Best Answer12-28-2018 16:21
12-28-2018 16:21
Hi, @RMINC! Unfortunately, Weather is one of the native apps and can't be uninstalled.
MakMak | Community Council
Best Answer12-28-2018 17:07
12-28-2018 17:07
Hi, what do you mean exactly with the wheater notification, cause AFAIK it never gives a notification. It will only give you the information when you go to the wheather app and press it?
Best Answer12-28-2018 17:11
12-28-2018 17:11
Are you using a custom watch face? Some of them have the weather info as part of the clock face. If this is the case then you will have to check the settings for that clock face itself and see if there is an off function, if not then you will have to get another clock face that does not have the weather feature built in.
