01-09-2025
08:51
09:14
AndreaFitbit
01-09-2025
08:51
09:14
AndreaFitbit
This is the second Versa 2 I have owned after I lost my first one. I bought it in August of 24 and it has had multiple issues. When first trying to update it, it took several hours and crashed dozens of times. Then, the display is stuck on dim mode and no amount of troubleshooting has fixed it. It has had numerous syncing issues in the past months. I have since factory reset the watch and I had to go through the hours of crashing updates again before it was usable.
Finally, yesterday the display stopped working. It is a black screen but is still responsive. I can start the stopwatch by remembering where the icons are and feeling the vibrations, but I cannot see anything on the screen. It would still vibrate when I get a text, but again, I can't see it on the screen. I cannot see if it is turned off to restart it because the Fitbit logo won't show up either. I tried changing the clock face but the watch won't sync so that is out of the question now too.
I was able to tolerate the dim screen, but this makes the watch useless. Very disappointed after I liked my first one so much.
Moderator Edit: Formatting.
01-11-2025 09:21
01-11-2025 09:21
Welcome to the Fitbit Community, @Grace050B. I'll be glad to assist with your Versa 2 screen query.
I understand how frustrating this could be and would recommend pairing your device with your account one more time:
If you encounter issues with your Fitbit device setup, refer to Why can't I set up my Fitbit device?
Best Answer01-11-2025 09:59
01-11-2025 09:59
This won't be possible. I can attempt to re-pair my watch, but it will not display the four digit code. The watch will buzz as if it were working, but the screen will not display anything. Without the four digit code, I cannot proceed.
Best Answer01-14-2025 08:02
01-14-2025 08:02
Thanks for getting back to us and for trying the advised troubleshooting steps @Grace050B. Our Team will be more than happy to have a closer look at this.
Please fill up this form with all the needed information. Our Team will reach back to you afterwards.
Please keep in mind, that this form is for you alone. If other users try to fill it up, they might not get an answer from Support.
