03-22-2022
10:25
10:38
Hi there, @anna.johnston. Welcome to the Community Forums. Thanks for the details provided in your post about the issue with your Versa 2.
This may be happing because you're not doing an exercise outdoors, therefore, the GPS connection is lost. Note: If the GPS signal is lost during the exercise, a map might not appear in the Fitbit app.
Verify the following requirements; then try the troubleshooting steps if necessary.
If the issue persists, see if GPS connects after each step:
Hope that helps.
Hope that helps.
