My Versa 2 Heart Rate Tracking show wild abrupt swings during workouts (bike rides) after the most recent firmware update that included SPO2 Watch. Here is a comparison before and after
Before The Firmware Update (this is fairly accurate):Before the Most Recent Firmware Updates
After the Firmware Update to Version 35.71.6.19:
After the Most Recent Firmware Update
Nope there is no way I was at 40-50 BPM for several minutes during a fast bike ride. I have several bike rides before and after the updates and they both show consist in accurate results after the update.
FYI: I reset the watch to the factory settings, stopped and started it again. Nothing works. I can repeat this results every time.
Hi, I have seen this sporadically with mine also. For instance, I’ll be on my elliptical and it will all of a sudden drop to 40 bpm! It also wasn’t reflecting my HR on my walks. I did a manual shut down and re-start which for now seems to have fixed mine. On the watch, system, about, shut down. I don’t know if this will help you but wanted to say I’ve seen similar things with mine.
Is the SP02 watch face your default? I’d try a different watch face during the day after the shut down and see what your results are. I’m wondering if it might be somehow connected to that watch face.
Best AnswerManual restart does NOT fix this issue. I tried that few times. I have several bike rides that shows the same results. I do not have SPO2 watch face installed at this time, but there is no difference when I did have it installed.
