My Versa 2 is just over 12 months old and the heart rate monitor no longer works. The sensor on my wrist does not work and I can no longer track my sleep. It was fine until an update in July 2024.
I have tried all the troubleshooting options from similar enquiries and nothing has worked. Even tried a factory reset with no luck.
Any help would be appreciated!
Hi there @GabbyT11! Welcome to the Fitbit Community!
Thanks for sharing with us the situation you're having with your Versa 2 not tracking the heart rate anymore and for the steps you already tried.
Can you please verify if you have the setting "heart rate" activated? You can find this setting directly in your Versa 2 right in the Settings app > "Heart Rate".
Try this in order to receive heart rate data again:
- In the settings of your watch, turn off the heart rate.
- Sync the device. Please note that syncing is very important, otherwise the changes will not be applied.
- Restart the watch: press and hold the side button for 10 seconds.
- Sync the device with the Fitbit app.
- Turn the heart rate back on in the settings.
- Sync the device again.
Hi there @GabbyT11! Thanks for your reply and your efforts.
You could try a factory reset:
