08-25-2025
13:48
06:16
MarioSFitbit
08-25-2025
13:48
06:16
MarioSFitbit
Do you have to use a separate app besides the Fitbit app for Sp02 to work? If so, what is the name of the app you need to download?
Moderator edit - updated subject for clarity
08-25-2025 13:59 - edited 08-26-2025 06:21
@AES10 You must use an SpO2 clock face on the Versa 2 to get your SpO2. Help article There is an error in the article. Fitbit replaced Gallery with Watch faces.
Laurie | Maryland
08-27-2025 10:30
08-27-2025 10:30
@LZeeW Thank you for your help.
@AES10 A warm welcome to the Community! Thank you for your message.
Are you having difficulties with the SPO2 feature?
Do you get an error message?
If you are having difficulties with the SPO2 and the Versa 2. We ask you for a little patience.
Our team is aware of an issue with the SPO2 feature. They are looking into it and will work on a solution afterwards.
Hopefully this gets solved soon
Best Answer08-29-2025 09:36
08-29-2025 09:36
Fitbit said I needed to download an app, but the SP02 worked without having to do that. Thank you.
09-01-2025 14:09
09-01-2025 14:09
@AES10 , Thank you for your message and confirmation.
Our team is aware of this issue and is looking into it.
They'll work on a solution afterwards.
