06-22-2025
19:05
07:18
06-22-2025
19:05
07:18
I have a Versa 2 Fitbit. While trying to get last minute steps on Friday (it was charged to about 90% when I started walking) I suddenly discovered that the screen turned black and it was unresponsive. I tried pushing the button on the side to turn it on (didn’t work) then tried to plug it in the charger in case something went wrong with the battery (also didn’t work). Eventually I held the button on the side longer to reset the device. It went to the “download Fitbit” screen so I went back on the app and tried to have it pair. When that didn’t work I “deleted” the device from the app and tried to repair it completely. This worked up until the software/device update. It would show the update was progressing but would turn green and instead of continuing it would go back to the beginning of the update. I’ve tried many different methods to get it to try and work again but it keeps getting stuck on the software update by either turning green and restarting, crashing in the middle of the update and starting over, or crashing and going all the way back to the beginning with the “download the Fitbit app” screen.
Since this is getting long, here’s a general list of everything I’ve tried to get it back. I’ve tried:
I also downloaded the Fitbit app on a completely different iPhone and tried to sync it to the Fitbit app on there and it still would loop/crash so it’s definitely not phone related.
No matter what combination I do it keeps getting stuck on the software update loop.
06-24-2025 17:43
06-24-2025 17:43
Hi @djanec. Welcome back to the community forums.
Thank you for sharing with me all these information regarding the difficulty that you are experiencing with your device, and for developing every troubleshooting step to fix it.
Since you tried the steps and they didn't work and you report experiencing the same behavior, I need additional information from you that would best be shared privately. I’m sharing a link to a form for you to fill out so we can look into this further.
This form is only meant for you to use, so let me know once you’re done.
Best Answer06-25-2025 04:29
06-25-2025 04:29
Thank you, I filled it out!
Best Answer07-11-2025 08:06
07-11-2025 08:06
Fitbit user since 2018. 2018 bought Charge 2 and 2020 Versa 2. Versa 2 worn since purchase, on JUNE 22 when trying many times to force an required update it finally died. It would not finalize the update. It was exhausting trying to do all the things you have done to get it back working. Unfortunately since then can't get it to even turn on. Last since was 18 days ago (June 22, 2025). I miss my alarms, Alexa etc. Now faced on what to do. Thinking about buying another or switching to another tracker. Any recommendations?
Best Answer07-12-2025 07:38
07-12-2025 07:38
I would recommend making a separate post with all the info like I did to get the attention of the Fitbit support team. They did respond on here to my post, but what isn’t shown on here is that we been emailing back and forth to try and troubleshoot and figure out the next best steps. My Fitbit unfortunately is gone and will not come back from the update loop, so they then looked into the warranty and go from there. It will take a bit with the troubleshooting phase but they are very helpful. I’m currently waiting for my next paycheck and will be getting a new Fitbit. I’m definitely ready cause I miss mine so I know how you feel there!
Best Answer07-12-2025 09:20
07-12-2025 09:20
Thank you for the response. I am definitely out of warranty but was hoping Fitbit would offer a discount to purchase another. Couldn't pull the trigger yesterday with Amazon Prime. LOL 😩
