02-05-2020
13:43
10:01
LizzyFitbit
02-05-2020
13:43
10:01
LizzyFitbit
My touchscreen has stopped working even after repeated resets. Is anyone else having these issues?
Moderator edit: updated subject for clarity and label
02-06-2020
10:05
08:39
02-06-2020
10:05
08:39
Hi @SunsetRunner. Welcome to the forums.
Thanks for letting me know that your touchscreen isn't responding, as well for the steps tried prior posting. You did a good job! To further investigate, may I know the model of your Fitbit device? Also, did you try the restart process described here?
I'll be looking forward to your response.
Best Answer02-07-2020 02:25
02-07-2020 02:25
02-10-2020
09:59
08:38
02-10-2020
09:59
08:38
Hi @SunsetRunner. It's great to see you here in the forums. I'm sorry for the delayed response.
Thanks for confirming the steps tried for the restart process. I understand how you're feeling about your Versa 2 as it was a special gift given to you and it should be working well. Since the screen is still unresponsive, I've gone ahead and requested a case on your behalf so our Support team can give you a hand. They'll send you an email with more details, keep an eye on your inbox.
By the way, I've moved your post to the Versa Smartwatches board so we can keep our forums organized.
Best Answer03-06-2020 06:22
03-06-2020 06:22
I bought my Versa 2 in November 2019. Last week I tapped the screen to change from the calorie count to steps and it wouldn't change. I couldn't swipe down to get messages or get to the quick settings page. I finally did a restart. That lasted for a couple of days. I read the community forums and found that this is not an isolated issue. The touchscreen stopped working twice yesterday and the second time I have to restart three times in order for it to begin responding again. The problem appears to be escalating.
14:29
08:38
03-08-2020
14:29
08:38
Hi @jd010100. It's always great to see you here in the forums!
Thanks for letting me know that your Versa 2's screen doesn't respond correctly, as well for your research in the Community. You did a good job with the restart process and I'm sorry that your watch continues having this issue. I was able to contact our Support team on your behalf and shared your post so they can create a case for you. You'll receive further assistance about this matter via email, keep an eye on your inbox.
Best Answer03-12-2020 09:04
03-12-2020 09:04
Hi!
I've had this same problem for several months with my 15-month-old Versa. I've tried multiple times to do factory resets with no success. Then, last night, the battery drained completely (unexpectedly; I usually don't let the battery fully drain). I fully charged it this morning, synced it with my phone and the touch screen works again.
I hope this works for you too. Good luck!
Best Answer03-12-2020 11:15
03-12-2020 11:15
18:12
08:38
03-16-2020
18:12
08:38
Hi @Josie48 , welcome on board! @jd010100, it's great to see you here again. I'm sorry for the delayed response.
@Josie48, thanks a lot for sharing your experience with your Versa and helping our friend with your suggestions. I'm sure others will find your post very helpful.
@jd010100, I appreciate your efforts while working on this situation. I understand where you're coming from as your watch should have worked correctly. Our team often checks the forums to gather feedback shared by our members that helps us to improve our products, services and overall environment. While I don't have access to your case, let me suggest to reply back to the last email sent by our Support team so they can provide you with more details about your case.
For any warranty-related inquiry, please check our warranty policies here.
Best Answer05-25-2020 08:21
05-25-2020 08:21
I have reset mine numerous times I have unpaired I have uninstalled the app. I have tried everything from the app because I can't swipe to get anywhere on my watch. I purchased the versa 2 a couple months after I had gotten the versa because it did more. I gave my versa to my mother and her is working great. HELP
