05-14-2021
06:42
05:09
JuanJoFitbit
05-14-2021
06:42
05:09
JuanJoFitbit
My versa 2 battery life is getting worse. I have to charge it daily. Anything I can do to fix it?
05-14-2021 15:21
05-14-2021 15:21
Same thing is happening to me.
Best Answer05-15-2021 05:08
05-15-2021 05:08
Me too! Anyone respond with a solution yet?
05:09
10:35
05-15-2021
05:09
10:35
@Sam.j9303 @RubeeJeep Welcome to our Fitbit Community. Regarding the battery draining issue that your Versa 2 watches have experienced, I'd like you to try the tips that are listed in this help article in order to improve the battery life of your watch.
Finally, monitor the battery's behavior of your watches and see if the issue gets fixed.
Hope this helps.
05-17-2021 07:02
05-17-2021 07:02
I tried all these things and it didn't work--and it is getting worse. help!
04:17
10:35
05-18-2021
04:17
10:35
@abarb Thank you for joining us in this thread and our Fitbit Community. Thank you also for trying the recommended troubleshooting steps.
Since your Versa 2 is still experiencing battery draining issues, the best way to get help for this problem is to chat with us online or give us a call. Click here to get connected and our Support team will be happy to follow up and assist you accordingly.
See you around.
Best Answer05-18-2021 10:57
05-18-2021 10:57
This is a very well known issue, that unfortunately started earlier this year, after a screwed up update. Many people "lost" their fitbit due to no being able yo either sync, charge, hold charge, messed up heart rates, unable to even connecting to the phones and the list goes on.
Fitbit is well aware of this but clearly in denial. They run some more updates to fix the "broken" one, but again it gets worse. At the end of the day they label it as "solved" when its not. If you contact customer service it will be your fault, recommending a newer version of your watch ( of course with a discount ) or buy a new phone and theres always the replacement if you are still under warranty. But again that "replacement" option is even more frustrating and in most cases worse. You can read lots of topics on this forum about it, including my own experience.
Things that "worked" for me and by all means its not perfect but at least this saves my battery a bit was rolling back to a much older software version and disabling auto update and ignoring the update message everytime you start the app 😒
You wont be able to sync your data half of the time, or getting the message that no phone is paired, but hey its either that or a watch thats completely useless.
Maybe one day fitbit gets it together but i lost all hope, especially now with google being in charge. Good luck and i truly hope that you can find a way/option to get this working in a way that might be acceptable or tolerable for you.
