01-15-2023
17:50
03:47
01-15-2023
17:50
03:47
I had my charge go to 7% on my normal wear. Usually I charge to 99% and the next morning it’s usually around 84%. Now it quickly loses the charge.
01-15-2023
20:14
15:44
01-15-2023
20:14
15:44
Hi @hawaiichick - do try to restart the watch and charge fully to 100%, it may take an hour to get there from 99% but worth a try.
However a very rapid discharge of a day or less can indicate a watch fault such as water damage and look out for it getting hot (such high battery drain generates heat).
If it it gets hot when charging stop immediately and don't wear it to avoid being burnt.
I have the exact same problem with my Versa 2. Usually I would need to recharge battery every 4 days or so. With the past week I've had to charge it almost every day..
Did anyone get back to you with a solution please?. It is very nnoying.
