04-02-2020
05:44
10:47
DavideFitbit
04-02-2020
05:44
10:47
DavideFitbit
I purchased mine like 2 weeks back and everything as smooth. Last week did a firmware update. After that the battery life has been pathetic. I have to charge twice in a day. I already did a factory reset and uninstalled app which i dont use. And have tried everything I could to improve it. I wonder if anyone has any solution or suggestion on this problem. Or if someone else having similar issue?
Moderator edit: format
Hi, @Mansi12327! That's definitely not good. Is there any other reason the battery might be draining like an always on clock face? Other than that, I would suggest getting in touch with Fitbit Support, this is not normal behavior.
MakMak | Community Council
Best AnswerHi
As you've just updated sometimes it can take the new firmware a little while to settle and that can effect the battery life for a couple of days
It happens sometimes when on phones as well
If it persists contact support but see how it performs over the next couple of days
Best AnswerI contacted and they asked me to run a battery test which I am going to do and see how it goes.
Best AnswerThey sent me a new one and its been 2 weeks no problem at all.
Best AnswerMine is doing the exact same thing, I did the last update and added the new Spo2 clockface
But have since changed it because that was a suggestion, I've turned off my always on and I also set the device up again but the charge isnt even lasting 24 hours? I've had it for a year and never had an issue until now!
