Have been using versa to track swimming and running- works fine. Tried to track biking for first time today it only tracked time and NOTHING else.
i biked for an hour and ten minutes and really wanted to know distance to pace myself for upcoming sprint triathlon. Super annoying.
@Joybird68 did you simply hop on the bike and take off?
Or did you put the Versa into its bike tracking mode with its connected GPS? GPS needs to be used to get a map and direction.
I just do what I normally do when I start an exercise-hit the swipe for exercise, select the exercise I was about to start, and hit start. After I was done, when I noted it tracked nothing, I checked location settings and it was set to use GPS when I was using the app only. I presume if I had started the exercise that was akin to “using the app.”
@Joybird68 that is good, next time before tapping, check the top of your Versa and make sure that it says connected.
@Aaronlogan333 please keep your posts on topic. This is not a dating service.
@Aaronlogan333 if you are interested in knowing how this forum works, tap on the top right and read the Community Guidelines.
PS I have blocked and reported your private messages.
