03-03-2023 07:14
03-03-2023 07:14
My Versa2 screen suddenly went blank, just a white box. Help?
Best Answer03-06-2023 21:02
03-06-2023 21:02
Hi @Lunamadre - did you resolve the issue?
If not try restarting it. How do I restart my Fitbit device?
Also try charging it and if it gets hot stop immediately.
If you double tap the screen and swipe in any direction the screen is displaying correctly try changing the clock face from the Gallery tile in the Fitbit App.
Best Answer03-07-2023 06:35
03-07-2023 06:35
Best Answer03-07-2023 06:49
03-07-2023 06:49
@Lunamadre - use it on another Versa 2 and don't pay more than a new versa 2 or switch to another brand but best to avoid the more expensive Fitbits. Which aren't necessarily compatible with the 2.
In any case make a note of the names of your current clocks and apps (in the Gallery tile), it can come in handy later.
