My versa 2 screen went blank 5 days ago (it was fully charged at the time) and I have tried everything suggested to get it going. I have read forums, you tubed it, pressed buttons, you name it ive done it. My app says it is disconnected but I didn't do that. I need some more suggestions please.
Hi @ER-B - unfortunately from the symptoms it would seem the watch is faulty. This can happen if it got wet recently.
However things to try, if the app says it's charged and not connected, see when it last synced.
If that is 5 days ago it may now be discharged, so try charging for 30 minutes from a PC if you can.
Why? Because you can note the connection behaviour to the PC.
If it constantly connects and disconnects the watch is uncharged or faulty or the cradle is faulty when you add the watch to it and the PC doesn't detect it.
Note also if it gets hot which is a sure sign of a permanent defect and stop immediately if it does.
Hi @ER-B Welcome to the Fitbit Community! It's great to have you here!
@Guy_ thanks for the support.
@ER-B Thanks for letting us know about the situation with your Versa 2 screen that is blank, I'll do my best to help you. Thank you for trying to solve it before contacting me.
Please confirm the following?
@ER-B - just to make doubly sure, plug the cradle into the PC, then add the watch making sure it is the right way round and it is firmly pressed in place so the pins make good contact. You should get a connection noise with the PC volume up.
To help check, play a song to make sure the PC is not in silent mode.
If the watch stopped working suddenly it is very likely a fault with it, especially if it had synced with the app and it said it had a charge at that time. So it is important to verify that it was syncing at that time.
The Versa 2 is a great watch, and you may have difficulty getting another, more recent watches don't have all the features it has, and are more expensive, so see if any friends or family can help.
Hi @ER-B Thank you for trying all the suggested steps.
Thank you for sharing your comments. I understand how you feel and want to assure you that I'm doing our absolute best to find a resolution for your case.
@Guy_ thank you very much for the support.
@ER-B Since you have tried following all the suggested steps and your Versa 2 has not responded, I recommend that you continue directly with technical support so that they can tell you how to proceed now.
I have been in touch with technical support, or sort of. I have a case ID number but after 45 minutes waiting, screen saying, "in progress" I assumed that they will contact me when they have something to tell me.
Thanks for your help
Remaining hopeful
Edith
