09-16-2019 08:24
09-16-2019 08:24
What are the 2 clock faces used on all promo images for the Versa 2? Will we be able to use them on Versa 1?
09-16-2019 08:33
09-16-2019 08:33
Hi @SunsetRunner, welcome to the community.
The one on the left is called waveform and the one on the right is called sundial. I don't believe either will be available for Versa 1/Lite.
Best Answer09-16-2019 08:33
09-16-2019 08:33
Best Answer11-01-2019 19:11
11-01-2019 19:11
Any reason why not? Seems silly to just choose not to.support new faces made by fitbit
Best Answer11-01-2019 19:24
11-01-2019 19:24
Hi @JasonHartleb , it's very simple: since the screen of the Versa 2 is larger than the Versa 1, you cannot install Versa 2 CF's on the Versa 1. regards kuzibri
