09-14-2020
23:00
11:07
09-14-2020
23:00
11:07
My versa 2 worked for a few hours this morning and then shut itself off around 12:30pm. I put it on the charger before I went to work hoping it would restart but it didn’t. I tried holding down the side button but it won’t turn on. I had it for almost a year and I’ve never had any problems with it before.
Hi there @Crutledge08, welcome to the Community Forums. I'm sorry to hear that your Versa 2 has shut itself off, I understand how you must be feeling. Thanks for the details provided in your post and for your time and efforts in trying to solve the issue prior to posting here.
Does your Versa 2 vibrates when you connect it to the charger? If it doesn't, please try the recommendations below:
If the above steps don't work, at this point I recommend doing a factory reset (before doing so, make sure to remove your watch from your Fitbit account):
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
I'm looking forward to your response, keep me posted.
Best AnswerI tried all of these and it still isn’t turning on. It’s not doing anything. There’s no vibration, no symbol on the screen, nothing.
Best AnswerI am having the exact same problem. I’ve done all of those things as well and still nothing.
Best AnswerI'm having this same issue with the versa lite. The last 2 days it appears to die. It says my battery is dead even though it just charged, and then it seems to actually still track and vibrate but I can't get the screen on, even after trying to hold down the power button for 10+secs.
Best AnswerI contacted customer support and they are sending me a replacement because it is still under warranty. They said my last sync was at 82% on Monday morning around 1am. It stopped working 12 hours later.
Best AnswerI contacted customer support and they are sending me a replacement because it is still under warranty. They couldn’t get any response from it either. They told me my last sync was at 82% on Monday morning around 1am and it stopped working 12 hours later.
