04-27-2021
05:25
06:33
04-27-2021
05:25
06:33
Can’t sync, app can’t find my network when I’m standing gin front of my router. This happens often. My router is up to date, my app is up to date. Just one more bug with this crap Versa 2
04-27-2021 06:13
04-27-2021 06:13
If your phone can't find a network it is a phone problem, make sure you have wifi and data on on the phone, it should work with the data connection if the wifi isn't working. Try restarting the phone.
04-27-2021 06:38 - edited 03-18-2024 09:00
Hi there, @BB401. Welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2. I understand how you must be feeling. @Guy_ Thanks for helping out!
If you haven't done so yet, I recommend checking this help article Why won't my Fitbit watch connect to Wi-Fi?
If you continue having syncing difficulties after following the steps above, see Why won't my Fitbit device sync?
Hope that helps.
04-27-2021 08:07
04-27-2021 08:07
04-27-2021 08:19
04-27-2021 08:19
04-27-2021 09:04
04-27-2021 09:04
Hi there,
I have a similar problem as @BB401. I have a problem with sync Versa 2 with my phone. My phone is Nokia 5.1 Plus. So I check your page with compatible devices (Fitbit-compatible devices) and you write there that it is required Android 7.0 or higher. My Nokia 5.1 Plus has Android 10. The Android version should be sufficient.
I have also tried everything what you write on url Why won't my Fitbit watch connect to Wi-Fi? and Why won't my Fitbit device sync? several times. If I restart my phone and also restart Versa 2 and pair the smartwatch and phone again, synchronization works fine. A few hours from the new pairing, if I try to sync again, the Fitbit app will no longer find the smartwatch.
1. Could you please tell me why this is happening?
2. Is something more what I can try?
3. Is it problem with my phone or with Fitbit app?
04-27-2021 09:33
04-27-2021 09:33
It sounds like your Bluetooth or Fitbit App are being shutdown.
Try this
On the phone check battery optimizations [the options may be different in your version]
04-27-2021 13:17
04-27-2021 13:17
04-27-2021 18:07
04-27-2021 18:07
05-07-2021 07:16
05-07-2021 07:16
Hi @Guy_ ,
I tried all steps which you describe.Bluetooth and Fitbit app have set on "Don't optimize" and cache is cleared. I test it for a week and I still have the same problem.
Is there anything else I can try next?
(Thank you for your time.)
05-07-2021 08:35
05-07-2021 08:35
@IvajaYou seem to have done the troubleshooting, probably best to contact Fitbit Support directly. They may be able to help you.
05-07-2021 09:16
05-07-2021 09:16
