09-21-2020 11:50 - edited 09-27-2020 03:27
Since updating my pixel 3a to Android 11 I've been having issues with my Versa 2.
It's not been recording GPS with my runs, and the Fitbit app itself has become unstable and sometimes refuses to start and gets stuck on the Fitbit logo, or refuses to load data e.g. an exercise or a daily heart rate page.
The no gps is a killer for me as it was a feature I made almost daily use of.
I've tried reinstalling the Fitbit app which hasn't made a difference.
Poster Edit: Rectified subject; moderator's change was inaccurate.
09-27-2020 03:26 - edited 09-27-2020 03:26
I've now rectified my problems (though irritatingly my usual route is now being logged as 200m shorter than before 😞 )
For anyone else seeing this issue with Android 11: The default behaviour for GPS permissions in this version of Android is to only allow access to apps when the app is explicitly in use (i.e. In your hand with the the screen on).
For Fitbit devices without an on-board GPS (i.e. my Versa 2), the app requires access to GPS the background, so you must go to the GPS settings to allow access to Fitbit app all the time. YOU MUST DO THIS AS AN ADDITIONAL STEP - ANDROID 11 WILL NOT LET YOU SELECT THIS WHEN YOU'RE PROMPTED TO GRANT ACCESS.
Granting a host of other permissions has also rectified my issue with the app freezing on the Fitbit logo at startup.
09-22-2020 06:17 - edited 10-02-2024 11:52
Hi there @J-Bone, welcome to the community forums. I'm sorry to hear that your Versa 2 stopped connecting to GPS and your Fitbit app is not loading your data after upgrading your Pixel 3A to Android 11. I totally understand how you must be feeling as you rely on GPS for your daily routines. Thank you for the details provided in your post and for your efforts in trying to resolve this issue, I will be happy to continue to assist you.
As a first approach, please verify the following requirements; then try the troubleshooting steps if necessary:
If you continue to have issue, please see if GPS connects after each step:
If the Fitbit app is still not properly working when you try to sync your data, please see: Why won't my Fitbit device sync?
Let me know if you need further help, I'll be around.
Best Answer09-27-2020 03:26 - edited 09-27-2020 03:26
09-27-2020 05:52
09-27-2020 05:52
Hi J bone thanks so much for this. I'm actually on Android 10 but I think the latest Xiomi MIUI 12 had this added.
Could you clarify how you turn this setting on?
Thanks. A
Best Answer09-27-2020 06:35
09-27-2020 06:35
Hi Aro,
Steps as follows for stock Android (may be a little different on MIUI):
1. Go to the Settings app.
2. Select Apps and Notifications.
3. Select "All Apps" to get a list of everything installed.
4. Select the Fitbit app.
5. Select "Permissions"
6. Select "Location"
7. Select "Allow all the time" (rather than "Allow only while using the app")
There may be some other denied permissions too, I've blocked things like Camera and Microphone but enabled Phone and SMS so I get the notifications to my watch.
09-27-2020 08:18
09-27-2020 08:18
thank you! I was having the same issue, heading out for a run now, hope it works!
Best Answer10-02-2020 11:52
10-02-2020 11:52
Thanks, J-Bone! I've been trying to figure this out for a while now. It was these last instructions that did the trick!
Best Answer10-02-2020 14:11
10-02-2020 14:11
Thanks. Looks like it also suddenly affected Samsung Note 10+ with September update to Android 10.
The app should detect such situations and warn users!
