Versa 2 is showing the wrong time
ANSWERED
My time is different than my I phones time
1 BEST ANSWER
Accepted Solutions
Hi there, @Fritzabbie2. Welcome to the Community Forums.
Keep in mind that your Versa 2 may show the wrong date and time if it hasn't synced or has been unpaired from your Fitbit account. Your Fitbit grabs the time of the device you're syncing with.
To see when was the last time your watch synced or to check if it's still paired to your Fitbit account, tap the Today tab > your profile picture > your device image.
If you're running into syncing issues, please see Why won't my Fitbit device sync?
Also, note that the time on your Fitbit Versa 2 may be wrong after you travel to a different time zone or when clocks change for Daylight Savings. If you changed time zones and the time on your Versa 2 is still incorrect after syncing, make sure the time zone setting is correct. For more information, please see the help article shared by @alexthecat.
I've moved your post to the Other Versa Smartwatches board for organization purposes.
Hope this helps.
2 REPLIES 2
@Fritzabbie2 you can find the instructions to fix the time on your device here
Community Council Member
Amanda | Wyoming, USA
Pixel Watch 4, Inspire 3, Sense | Android
Hope this helps.
