04-09-2020 05:57 - last edited on 04-10-2020 11:34 by LiliyaFitbit
Hello
I have a versa 2.i put a passcode on it. it locked me our whilst I was washing my hair (10 attempts). it said "unlock with your phone"
I deleted the device and tried to reattach but it keeps giving that msg so i cant see the pin, please please help me fix it
Deleting the device means that you cannot unlock the fitbit from the app as it suggests and the only option available to you is to factory reset the fitbit and then set it up again as though it were a new device.
You can't use the normal method of doing a factory reset as it's locked so the procedure is:
I too added a PIN then I wanted to remove it. Here is what you do:
To remove the pin you need to:
