03-27-2020 14:53
03-27-2020 14:53
My Versa 2 stopped syncing with the Fitbit App on 18 March. I deleted and reinstalled the App a couple of days ago. However the phone and Versa won't connect. I get to input the 4 digit code and then they refuse to connect.
I have done the usual, tuned the Versa off and on again several times, disconnected Bluetooth several times. And yes the pjone and Versa are fully charged.
I've even uninstalled the App a couple of times too and rebooted the phone. But they refuse to connect.
Has anybody any idea how I can resolve this please?
03-27-2020 20:27
03-27-2020 20:27
Hi @Ghost1 Which 4 digit code is it asking for? Is it your lock code for your Versa? Or are you setting your Versa up again as a new device and it is asking for the code on your Versa screen?
Helen | Western Australia
Best Answer03-28-2020 02:43
03-28-2020 02:43
Best Answer03-28-2020 05:06
03-28-2020 05:06
Ok thanks for that. What phone are you using?
Try THIS Help Article on Set Up issues and see if anything there works for you.
Best Answer03-28-2020 10:39
03-28-2020 10:39
I'm using a Samsung J5. Tried all the suggestions on your link and still failing.
Best Answer03-28-2020 16:39
03-28-2020 16:39
Hi @Ghost1 Unfortunately the J5 is not on the Supported Devices List which may be the problem. Unsupported phones may work for a while but if the connection is upset by an update to phone or tracker, no one is working towards getting it connecting again. As the Help Article didnt actually help, probably the best thing to do is to contact Support and see if they have any ideas which may help you.
Best Answer09-24-2020 02:48
09-24-2020 02:48
Same issues. iPhone 8plus. Any help out there?
Best Answer09-24-2020 11:49
09-24-2020 11:49
