05-21-2021
04:45
09:58
WilsonFitbit
05-21-2021
04:45
09:58
WilsonFitbit
My Versa 2 will not sync and my clock will not set
Moderator edit: subject for clarity/format
Best Answer05-21-2021 10:06
05-21-2021 10:06
Hello @lilacfairy. Welcome to the community forums!
Thank you for the information. For the syncing inconvenience, I'd recommend performing the following troubleshooting steps in this link: Why won't my Fitbit device sync?
Regarding the time, it should correct itself after syncing, but if you're able to sync it and the time is still incorrect, I suggest making sure the time zone setting is correct. For more information, please check: How do I change the time on my Fitbit device?
On a side note, I've moved your post to the Other Versa Smartwatches board to keep our forums organized.
Hope this helps.
