05-07-2025 11:47
05-07-2025 11:47
My Versa 2 says "Your Versa 2 is permanently locked because you entered your PIN code incorrectly too many time. If you proceed, we'll clear out the wallet settings of your Versa 2. Contact support for more assistance." How do I fix this?
Best Answer05-07-2025 13:01
05-07-2025 13:01
(Not about SDK; moved to correct forum section.)
Best Answer05-07-2025 16:47
05-07-2025 16:47
@Gondwana Thank you for your help, keeping the Community in order.
@C-O5 A warm welcome to the Community! Thank you for your message.
Just to confirm and avoid confusions, where do you see the message in the Fitbit app or on the Versa 2 itself?
If possible could you attach a picture with the message on your reply?
In the meantime, try changing the pin of the wallet over the app: How do I reset the PIN code for my Fitbit device?
