10-21-2019 20:34
10-21-2019 20:34
Hello, when I used the original Versa, it would pause as I would be working out since I would accidentally press the pause button as I am working out. Is this a problem with the Versa 2 as well? I am thinking of upgrading to the 2
10-22-2019 00:36
10-22-2019 00:36
Hi @ChrisOcon, welcome to the community.
The Versa 2 has had both physical buttons on the right hand side removed, so the only way to pause a workout now is by pressing the on-screen pause button. If you were pausing your workout by accidentally pressing one of the right hand side hardware buttons on your original Versa, then I believe your experience with the Versa 2 will be an improvement. However if it was the on-screen button you were accidentally touching, I'd say you would most likely experience the same issue with the Versa 2.
Best Answer10-22-2019 00:36
10-22-2019 00:36
Best Answer10-22-2019 11:13
10-22-2019 11:13
Thank you, that was the main problem I had with the Versa, the two buttons would pause and sometimes pause/finish a workout
