03-12-2023
13:51
14:54
03-12-2023
13:51
14:54
The screen is flickering black and white constantly. In between flickering the screen is very dim.
Tried restarting, rebooting, brightness. Everything on the forum that has helped others but not changing anything.
What’s
03-12-2023 14:55 - edited 03-06-2024 07:43
Hi there, @Katliz1960. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
03-12-2023 18:18
03-12-2023 18:18
I’ve done everything that you suggested, nothing changed. What do I do?
03-13-2023 07:47 - edited 06-03-2023 11:45
@Katliz1960 Thanks for following the tips and recommendations I've provided above.
I've created a case to get you in contact with our Support Team about this. They will be able to work with you and review your options. Please keep a lookout in your inbox to the email address associated with this Fitbit account. Someone will be in contact with you soon!
03-13-2023 10:09
03-13-2023 10:09
