10-05-2025 08:07
10-05-2025 08:07
Lately, my Versa 2 screen brightness has been stuck on dim. Even weirder, the brightness is set to normal, and sleep mode has been off. I've tried all troubleshooting methods. I've restarted it, checked for updates, and factory reset it several times, and nothing has worked. I also haven't seen any options for auto brightness. Is there still a way to fix this issue?
Thanks.
10-05-2025 16:37
10-05-2025 16:37
@B-Man1205 Hey there, welcome to the community.
Thanks for sharing this issue with us; those steps were great! Let's try something else.
In addition to the steps you've already taken, you can try changing your clock face. Sometimes the device can get glitchy, and although you've performed a factory reset, it won't hurt to try this. You can follow these steps here.
10-05-2025 18:12
10-05-2025 18:12
I just tried this, none of the clock faces fixed the brightness. Any other suggestions?
10-07-2025
08:50
09:19
MarioSFitbit
10-07-2025
08:50
09:19
MarioSFitbit
My started the same issue fro the last month
I've also tried the watch face idea. that did not work for me neither
Moderator edit - merged messages
