03-21-2024
15:12
05:48
03-21-2024
15:12
05:48
Hello! My Versa 2's screen is unresponsive. I've tried
It seems to be functional otherwise.
Thoughts? Or if there's any other way to do a factory reset of the watch (without the screen), that will also solve my problem.
Thanks.
The problem is over for me...I've put the old watch in the electronics recycling bin.
Allen
Hi there, @AllenCohn. Welcome to the Fitbit Community Forums. Thanks for bringing this to my attention and for the troubleshooting steps you've tried. I'm sorry to hear that the screen of your Versa 2 is still unresponsive. I understand where your concern is coming from, we're here to help!
I've seen you contacted our Support Team just right after posting here and they've already assisted you. If you have any questions regarding the outcome of your case, please don't hesitate to reach out to our team again. Since you already have a ticket open with them it'd be easier to continue the follow up on this matter with them directly.
Thanks in advance!
Best AnswerHi, Maria,
Your reply is only partially correct: although I did contact the support team, they did not come up with a solution (and closed the case).
So I still need to find a way to do a factory reset without using the touch screen.
Can anybody help?
Allen
Have same problem. Green flashing light on back still working but no screen. Charging doesn't help.
Best AnswerI'm having the same problem. Versa 2 screen is black. Long hold of button brings me to "Set Up Alexa" screen. Cannot swipe in any direction for new screen. Long hold of button here only brings me back to black screen.
Best AnswerI have the same problem- screen blank and not responding etc. led’s are flashing and data is sent to my iPhone app but I can’t see the clock face - a very basic failure of a ‘smart’ watch!
I tried all the resets soft and hard, charging it, the screen does work as it allowed me to factory reset the watch but when I continued the reset the automatic update to the latest firmware took place and guess what the screen was totally blank after the update! Faulty firmware software is my suspect!
Best AnswerI have the same problem - touchscreen is not responding despite resetting. Any ideas?
Best AnswerI have the same problem. Started a few days ago.
Stuck on "Reset Failed" screen. Touchscreen does not work. Holding down side button does nothing. Still seems to be tracking stats though, because I can see updates through the app/online.
Hi I have the same problem screen unresponsive but have green light phone will buzz and recording stats on app but screen is black I have been through support done all trouble shooting like you I am looking for a way the factory reset the watch without using the watch screen which is unresponsive. Support said I would but contacted by e mail but as of now it had an e mail. This seems a recurrent problem for many users. Can someone from Fitbit please respond hopefully with a solution
