I have had my versa 2 for about 14 months about 4 days ago it decided to run through the screens by itself i noticed i was unable to tap to get to any other screen but the screen it was on. Well today it started noticing that tje screen was dim but would allow me to move through the screens. Later on this afternoon it started woth this glitching of sorts and a fuzzy over lay them it went to a full white blank screen. I have turned it off turned it back on fully charged it changed the faces on it and i dont no whats going on with it. Can some one help
Make sure the button is working properly. A simple press should blank the screen or wake it consistently.
Probably best to contact Fitbit Support directly. They may be able to help you.
