03-16-2020
19:43
05:04
JuanJoFitbit
03-16-2020
19:43
05:04
JuanJoFitbit
Anyone else having an issue with their Versa 2 not allowing you to scroll through the different pages on the Fitbit? First it would freeze halfway to the next screen and now nothing. I cannot get to settings or anything. This started happening a few weeks or so.
07-26-2023 11:13
07-26-2023 11:13
This is the second time I've experienced this. I restated to no avail. The last time I put it in the charger and it started scrolling. However, I'm also having a problem keeping my exercise workouts. One keeps dropping off.
03-17-2020 05:03
03-17-2020 05:03
@Bdarin, welcome to our Fitbit Community. I'm happy to assist you with your Versa 2 since the screen won't scroll through pages.
I'd like you to restart your Versa 2 as described in this help article. This will refresh your watch internally. Once you've done this, monitor your watch and see if the issue gets fixed.
Keep me posted on the outcome.
03-17-2020 13:54
03-17-2020 13:54
First, thank you for responding. Unfortunately, I’ve restarted the Fitbit 4 times and still it’s not working as it should/not at all.
04-07-2020 17:02
04-07-2020 17:02
Having the same issue!
any resolution?
04-07-2020 20:08 - last edited on 06-03-2020 20:06 by LiliyaFitbit
Yes, received some feedback from their twitter account. Someone emailed me from Fitbit about hard reset which I did but it failed. They are sending me a new one.
Best Regards,
05-09-2020 09:52
05-09-2020 09:52
My Versa 2 is doing the same thing. Did you have to send in the broken Versa with the purchase receipt to receive the replacement?
I have no idea where our receipt is so I might be out of luck.
05-09-2020 10:04
05-09-2020 10:04
05-09-2020 12:06
05-09-2020 12:06
Hey Randy.
i spoke to someone at Fitbit. They directed me to repeatedly turn it off and on. That didn’t work. They then had me do a hard reset. That caused it to not work at all.
finally they said they’d send me a new one. They did send it and didn’t require me to send in the broken one. Also, they needed to know the order number I had when I purchased it. I did it online and found it in my old emails. They sent me a new one and it works great. To be honest, I’ve bought 3 Fitbit’s in my life. All three of them had to be replaced at some point because they were faulty. I think I’m done with Fitbit. That is a really bad record if I had to replace all three.
06-03-2020 17:50
06-03-2020 17:50
How do you do a hard reset?
06-03-2020 17:51
06-03-2020 17:51
The link is broken on that help article. My Versa no longer scrolls - seems to be timed to a software update.
06-03-2020 18:35
06-03-2020 18:35
Contact Fitbit support and they'll guide you. Just let them know you cannot scroll on your face. I got my replacement yesterday.
07-05-2020 11:57
07-05-2020 11:57
I have been having a problem with scrolling through the Versa 2 screens as well. I have held down the single button on the side of my Versa 2 and it appears to reboot but I am still unable to scroll through the screens.
Should my next step contact Customer Service? I purchased my Versa 2 in December 2019.
07-05-2020 12:03
07-05-2020 12:03
Yes, go ahead and contact them. They'll guide you through the steps you need to take to get a replacement. It's a fairly simple process.
07-05-2020 12:04
07-05-2020 12:04
That's also when my Fitbit was purchased.
07-05-2020 13:41
07-05-2020 13:41
07-05-2020 13:47
07-05-2020 13:47
I didn't have to send proof of purchase, either, just when and where it was purchased. They sent me a new watch without returning the old one though.
07-26-2023 11:13
07-26-2023 11:13
07-26-2023 11:41
07-26-2023 11:41
Same issue here just started this problem today out of the blue
