02-08-2021
20:56
05:22
02-08-2021
20:56
05:22
4 night ago I put my Versa 2 on charge (fitbit charger) and when I woke up the screen was black and hasn't turned on since. I thought I didn't sit it properly on the charger, still didn't turn on. However there is a green light kit on the bottom AND the app shows I have 68% battery life. I've tried everything I could find to fix the issue... Trying to power off.... Didn't work, couldn't even tell if it turned off or on. Tried to do an update, another fail.
Last thing I recall was hitting my daily steps goal (fireworks) and then putting it on charge at bed. Since then it's been a paper weight (not as heavy though 😉)
What can I do? My FB is only 1 year old.... is a Warranty replacement possible?
Best Answer02-09-2021 05:25 - edited 02-20-2024 11:58
Hi there @Michelleslibert, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
Are you feeling any sort of vibration when plugging your watch into the charger? If you're not, please follow the below steps:
I've moved your post to the Other Versa Smartwatches board for organization purposes.
