02-27-2023
18:42
03:57
CindyMFitbit
02-27-2023
18:42
03:57
CindyMFitbit
I woke up to my Fitbit Vedda’s screen being white. After a little the issue corrected. The 2 days later the issue occurred again when an alarm in the morning went off. It worked prior to the alarm going off. I am able to turn the alarm off by touching and still feel vibrations when a text comes in. My Fitbit has no trouble syncing.
I have tried to restart the device and the screen goes black then white again but never shows the Fitbit logo. I have also tried changing the clock face and restarting but that did not work.
Hi there @cr8482. Welcome to the Community Forums. Thanks for the details provided in your posts about the issue with your Versa 2 and for the troubleshooting steps that you tried prior posting.
If you haven't done so yet, I'd recommend following the troubleshooting steps provided here: Why isn't my Fitbit device's battery charging?
If that does not work, try the following:
Let me know how it goes.
Best AnswerI tried following the steps and it isn’t working. I can’t be sure I am doing it correctly because the screen is just white, and the vibration happens immediately after pressing the side button. No matter what I do the screen is white and I can’t see anything else.
