Versa 2 screen won't swipe
ANSWERED
Since I updated my Fitbit my screen isn't working properly. Can't scroll through anything. I've reset, factory reset, and changed the clock. Nothing has worked
1 BEST ANSWER
Accepted Solutions
Hello there, @SunsetRunner. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
To better assist you, please make sure you've restarted your Fitbit device as suggested here How do I restart my Fitbit device?. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
Looking forward to hearing from you.
1 REPLY 1
