02-16-2021
06:08
12:17
02-16-2021
06:08
12:17
Hi, I had my fitbit versa 2 for about a year. And one day when it froze so I tried to restart it. It powered off but then I was not able to power it back on. It only showed the logo when I press the button to power it on. I have tried to recharge it and tried to reset it to the factory setting (using the method found in this forum) but nothing worked. I am wondering what would be the next step. Any suggestion is appreciated!
02-16-2021 12:23 - edited 09-08-2023 09:38
Hi there @JudyZhang, welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
I'm not quite sure if you did manage to finally turn on your watch? If not yet, please see Why isn't my Fitbit device's battery charging?
In case your watch is still stuck on the Fitbit logo after being turned on, I suggest trying the following:
If you can't get started with your Versa, usually a missing requirement is the cause. Carefully review the requirements provided in the help article: Why can't I set up my Fitbit device?
Best Answer02-16-2021 12:23 - edited 09-08-2023 09:38
Best Answer02-16-2021 14:39
02-16-2021 14:39
I tried what you suggested and I still was not able to turn on my fitbit Versa 2. The only screen I saw was the logo screen.
Best Answer02-16-2021 21:17
02-16-2021 21:17
What happens when you
In the phone Fitbit App Click on profile photo [top left] Click on + Set up a Device Follow the installation instructions |
Best Answer02-18-2021 06:46 - edited 09-07-2023 07:06
@JudyZhang Thanks for following the steps provided to you.
At this moment, I’ve reached the limits of what I can do for you here on the public community forums. The best way to get help for this problem is to chat with us online or give us a call. Click here to get connected. I'd suggest to share this community link (thread) so our Support Team can be aware of the steps you've done, this way you could also avoid repeating yourself once again.
Best Answer02-19-2021 11:56
02-19-2021 11:56
Best Answer02-19-2021 12:24
02-19-2021 12:24
@JudyZhang Any time! We hope to have you back on track soon.
