01-26-2023
00:12
14:27
01-26-2023
00:12
14:27
Hi there,
I have tried all options mentioned in the forum on how to restart my Versa 2, but nothing has worked so far.
Tried the holding button 8-10 seconds, release 2 seconds, try again. No vibration and logo keeps flashing.
Tried the disconnect from bluetooth, force stop etc as well as uninstall and reinstall app but logo still just keeps on flashing.
Any other ways to fix this problem please?
Many thanks
01-26-2023 14:33 - edited 11-28-2023 02:08
Hi there, @Ward2099. Welcome to the Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
As our last resort, I'd suggest performing a factory reset by following the steps below (please make sure that your Fitbit device is no longer paired to your phone's Bluetooth before performing this step):
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account and your applications, alarms, etc.
Hope this helps.
Best Answer01-26-2023 14:33 - edited 11-28-2023 02:08
Hope this helps.
Best Answer01-26-2023 16:03
01-26-2023 16:03
How long have you had yours?
Best Answer01-29-2023 01:03
01-29-2023 01:03
Best Answer02-07-2023 03:00
02-07-2023 03:00
