02-05-2023
15:55
06:49
02-05-2023
15:55
06:49
I tried to reset my Versa 2 and now the screen with the dots just keeps going on and off. It won't do anything else. It's not syncing either. Any ideas?
Hi @mstalnaker - after a factory reset the watch has to be setup as it is like a new watch.
First remove the Bluetooth entry from the phone then in the Fitbit App click profile photo and "+ Set up a Device" and replace.
Before proceeding, in the Gallery tile note the names of any clock faces or apps you use to make it easier to install them again if necessary
What was the problem that needed a factory reset?
Hi there, @mstalnaker. Thanks for stopping by in the Community Forums and sharing the details about the issue with your Versa 2.
I've seen you contacted our Support Team after posting here and they've already assisted you. If you still need help or have any questions/concerns regarding the outcome of your case, please feel free to contact our team back for further assistance.
@Guy_ Thank you so much for your help!
