05-20-2022 10:01
05-20-2022 10:01
My fit bit is stuck on set up my wallet
I have
Press the left button for 10 to 15 seconds and longer
Remove the device from my phone and reinstalled it
Let the Fitbit versa to run out of power and recharge
and combinations of above
ive tried everything and my back button will not allow me to restart my device
none have worked Help ?????
05-20-2022 11:57 - edited 05-20-2022 12:08
Hello @Eestw2011
I’m understanding that your screen is stuck at the wallet screen and restarting dod not resolved the issue. Can you try restarting your Versa 2 a few times first? If that doesn’t work and your still stuck try this:
I’m hopeful this will fix the issue. If you want keep in mind that you can replace the Wallet App shortcut for any other option. To do so, on your Versa 2 swipe to Settings and tap the Left Button option. It is here where you can configure what a single and double tap of the button will open. Replace the Wallet App for some other function. This way it won’t happen again. Fingers crossed
😃Hopefully this will get you up and running again. Keep me posted
05-20-2022 14:21 - edited 11-14-2023 11:14
Hello there, @Eestw2011. Welcome to the Community Forums. Thanks for trying to troubleshoot this inconvenience with the Wallet app before reaching out. I understand where your concern is coming from.
Usually that screen will appear when opening the wallet app on your watch by either tapping on it or with left button to access to the shortcuts. While it's not possible to delete the wallet app, please give a try to the following steps to reconnect your watch to your account:
Additionally, as @SunsetRunner has mentioned, please keep in mind that you can replace the Wallet App shortcut for any other option. To do so, open the Settings app > and tap the Left Button option. The possible shortcuts vary based on your device.
Hope that helps.
