01-08-2024 11:46
01-08-2024 11:46
Hi there @san2972, welcome to the Fitbit Community.
Thanks for taking the time to talk to us about your experience.
In this instance, I would advise attempting to change out the clock face for one that is available on the Fitbit App Gallery. Additionally, you can try a standard reset of your device by just holding down the left button for ten seconds.
01-08-2024 12:09
01-08-2024 12:09
I'm having the same problem. My Versa 2 has a password/lock screen which activates when I first put on my watch. The numbers on the left side of the screen are not working - 1, 4, 7. Without being able to use these numbers, I can't open my watch.
I have tried the reset suggestion and it did nothing.
01-09-2024 05:24
01-09-2024 05:24
Hi there @Und41, welcome to the thread and the community.
Thank you for taking the time to describe the situation to us. In this case, I would advise using a pin that excludes the numbers you mentioned in order to access your device. You can complete this directly from the Fitbit app by following these instructions.: How do I reset or change the PIN code on my Fitbit device?
Once you've finished, I advise you to change out the clock face and try restarting.
10:44
13:56
AndreaFitbit
01-09-2024
10:44
13:56
AndreaFitbit
Hi there, i don't have a pin, this is from another user. My screen does't
respond on anything. When i swipe nothing happens.
Hello, i'm sorry i missed this one. I had a fitbit clock interface, but i
Just chanced it to another one from the fitbit gallery, and resetten My
fitbit. Hoever i'm experiencing stille the samen problems.
Grz Sandra
01-13-2024 06:28
01-13-2024 06:28
Hi
I have changed the click & tried a reset but my screen still sticks where it will either not move & let me click on an activity or when I do it won't end the activity.
