09-01-2019 07:01
09-01-2019 07:01
Will you be able to use Alexa to send and respond to text messages?
09-01-2019 07:24
09-01-2019 07:24
Yes
https://youtu.be/T1PS0KpWaIU?t=07m19s
09-01-2019 07:24
09-01-2019 07:24
Yes
09-01-2019 07:27
09-01-2019 07:27
Hi @Dhamidy
You will be able to respond to text messages if you are an Android user. Unfortunately this will not be available on iOS (Apple limitation), just as the canned responses aren't either.
01-06-2020 10:41
01-06-2020 10:41
That's not what was asked. That's reply.
Can you use Alexa to send a message to someone just by saying their name and the message?
I keep getting the "Sending messages is not supported by this device" in the alexa screen when I try to do this. Is some setting wrong? my permissions on the Alexa app are all enabled.....
Best Answer01-06-2020 12:20
01-06-2020 12:20
No you cannot do what you are asking.
Best Answer01-06-2020 13:51
01-06-2020 13:51
05-26-2022 13:19
05-26-2022 13:19
I used to have the reply option, then one day it just disappeared. I tried updating the app and still nothing.
