12-28-2020
02:52
04:35
12-28-2020
02:52
04:35
I’m charging my versa 2 for the first time and it won’t fully charge. ( battery doesn’t look full on scream) Why is this?
thanks.
Hi there @Sammy37, welcome to the Community Forums.
Please note that charging your device to 100% may take 1-2 hours. While the watch charges, tap the screen twice to check the battery level. Tap again to use it while it charges.
Take into consideration the following tips for charging your Versa 2:
If your watch is still not charging after taking into consideration the above, please follow these troubleshooting steps Why isn't my Fitbit device's battery charging?
Let me know how it goes.
@Sammy37 I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
