01-21-2021
04:04
05:01
01-21-2021
04:04
05:01
Last night my fitbit versa 2 went completely dead. Was on my wrist at the time but was completely unresponsive. It had plenty of charge in it but I placed it back in the charger but was still dead. It was only bought at Christmas so not even a month in use. Any suggestions?
Hi there @sodonnell, welcome to the Community Forums. Thanks for sharing the details about the issue with your Versa 2.
Please restart your watch. For more information, see How do I restart my Fitbit device?
If the restart doesn't seem to work, please verify if during this process your Versa 2 has vibrated. If it hasn't, please:
Let me know how it goes.
Best AnswerHi,
When I hold down the power button it doesn't switch on or off and no vibration. It is lifeless. I wiped down the back and tried using a different charging point but still dead. It doesn't vibrate at all. There was plenty of battery left in it yesterday before it went dead.
@sodonnell Thanks for the update!
As our a resource, I'd recommend performing a factory reset on your Versa 2. Before doing that, make sure to remove your watch from your Fitbit account and phone's Bluetooth settings. Then, please:
You can follow the steps to set up the device after that: How do I set up my Fitbit device?
Take into consideration that a factory reset deletes any stored data, which includes all data that hasn't synced to your Fitbit account, your applications, alarms, etc.
Keep me posted on the outcome.
Best AnswerDisconnected from the Fitbit app and the Fitness pal app.
Held the button but no vibration or logos appear or disappear - just a black screen
@sodonnell I appreciate you had followed the tips and recommendations provided above. Since this sounds a bit more serious, I've created a support case on your behalf - you should receive an email from Customer Support at the email you used to register with the Community forums. Note that we may take a bit long to get back to you since due to recent events affecting our operations, support options are limited and wait times are longer than usual.
