05-22-2024
19:22
07:59
05-22-2024
19:22
07:59
The swipe up function is not working on my Versa 2. When swiping up it shows the logo then goes back to the clock screen. Thoughts??
05-22-2024 20:55
05-22-2024 20:55
Hi @akmamabear83 - it seems the Today app is corrupted and to fix it you will need to do a factory reset (not without risk, especially if you don't wait long enough).
It is a good idea to make a note of the names of any clocks or apps and any special watch or app settings you use before the factory reset and setup again.
05-23-2024 07:58
05-23-2024 07:58
Hi there, @akmamabear83. Welcome to the Fitbit Community Forums. Thanks for the details provided in your post about the issue with your Versa 2. We're here to help!
Before considering the factory reset as suggested by @Guy_, I'd recommend the following steps:
If the above doesn't work, please restart your Fitbit device as suggested here How do I restart my Fitbit device? Note: Restarting the device doesn’t delete any data. If the restart doesn't work try to change your clock face. If this fixes the issue, you can change your clock face back to the original clock face.
