08-22-2023
02:43
09:44
08-22-2023
02:43
09:44
My versa 2 has stopped syncing, or just does it randomly. I have uninstall fitbit app and reinstalled , turned off Bluetooth, removed versa 2 and re instated. Use it mainly as a watch but the time is never correct.
08-22-2023 09:46
08-22-2023 09:46
Hi there, @Gone2pot. Welcome to the Fitbit Community Forums. Thanks for trying to troubleshoot the issue with your Versa 2 before reaching out.
In addition to the steps you've done so far, please try the following:
With the steps above, what I want you to do is to pair your Versa 2 first to your phone's Bluetooth settings before any other Bluetooth device is connected to your phone.
Once you manage to sync your Versa 2, the time should be corrected. Keep in mind that your Fitbit device uses the time of the device you're syncing with.
Best Answer08-25-2023 23:20
08-25-2023 23:20
Good morning thankyou for your comprehensive reply. It has not fixed it at all. I have tried every different combination of turning things on and off and uninstalling and reinstalling. My phone recognises the versa 2 but just won't connect.
any other ideas? I did attach screen shots but was not permitted
Thanks to send.
Helen
